The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Phone charging but not charging
My daughter got slobber in charging port. I was able to dry it but unfortunately my phone doesn't charge it stays at 1% when it's off and when I turn it on it goes down to 0%. Any suggestions on how to fix it?
Score 1
Add a comment
1 Answer
Hi!
Check if there is corrosion on the pins. If yes, try to clean it with isopropyl and then dry it again.
If it’s still not working, replace the charger port (it’s not soldered on the motherboard, and it’s the best thing to do anyway). Before you order a new one, open it up and check if there is corrosion anywhere else, if yes, clean it and check if everything else is working. Order the part, build it in and enjoy!
Add a comment
Add your answer
jackiejacklin63 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 280
