Repair guides and disassembly information for Microsoft's Surface Pro X, an ARM-based Windows tablet, released in November of 2019.
Surface Pro X SSD Swap
I notice that the SSD in the Surface Pro X looks a little different than the pictures I have seen of potential replacements (still looking, have not found any available). The connector has only one notch and it appears quite a bit thicker. Is there some shielding that needs to be removed or moved to new SSD?
Score 1
Add a comment
Chosen Solution
Have since returned the Pro X and went for a Laptop 3 due to Win10 issues. Same SSD so process still applies.
Thank you.
Add a comment
Most Helpful Answer
No issue that I have found. There is a post here on replacing the SSD.
Microsoft Surface Pro X SSD Replacement
There are several options but I’ve only personally done it with the Kioxia BG4 M.2 2230 SSD.
Score 3
Add a comment
Add your answer
Valther Nielsen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 756
