Released March 2017, Identified by model number SM-J727
Which screen repair kit?
Can someone please tell me which screen repair kit should be used on a Samsung Galaxy model
SMJ72TV
Thanks
Add a comment
1 Answer
If you're looking to buy a tool set for diy phone repair, you should check your local stores for the best set. I don't know which country you live in so I can't recommend any stores. However, Amazon has a lot of sets you can check.
  • Notice! Don't buy really cheap tools. If it comes to own a fine small sets of tools, you should go for the good ones to prevent damaging your phone..
I'm currently using the Kobalt tool set, it has everything i need specially for iphones.
Have those ready:
  • A fine tip tweezer.
  • Phillips screwdriver #000
  • A magnetic sheet to hold the screws or a small box.
  • Plastic triangle opening tool.
  • Heat gun.
  • an adhesive tape 2mm wide.
Add a comment
Add your answer
mike flora will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 235
