The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
How can I fix this connected disconnected charging issue?
When I plug it in it charges for a bit and the soon starts rapidly charging and stopping. Nothing is touching it and I've tried fidgeting with the charger by the charging port but it doesn't change anything. I've also tried with other cables and they don't help. Is there any way to fix this?
Add a comment
1 Answer
Most Helpful Answer
Paige Jandreau  since you already tried all external solutions, you may have to replace the charging port. Your phone uses a flex connection for that. So, time to take it apart (PITA) Use something like this video to get into your phone. This is the part you will have to replace.
Score 2
1 Comment:
Thank you so much!
by
Add a comment
Add your answer
Paige Jandreau will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 41
All Time: 798
