The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
The screen is not acting correctly
for some reason the screen goes to to a flickering black screen. then it some time goes to a green screen and starts to great out how do i fix it.
Add a comment
Most Helpful Answer
Hi,
Has the tablet been dropped or gotten wet at all?
If it has just been dropped (or even if it hasn’t) the problem could be a loose screen flex cable connection on the systemboard or perhaps the screen is failing internally and it would need to be replaced.
If it has gotten wet then you may have more problems which can only be addressed once the tablet has been opened and inspected. In the meantime, don’t turn it on or try to charge it as this may increase the damage to the components.
Here’s a link to the ifixit Galaxy Tab S 10.5 guide which shows you how to open the tablet so that access to the flex cable connection is possible so that it can be checked and if it is OK.
Here’s a link to a video that shows how to replace the screen if it is determined that that is the problem.
The answer below shows the cost of a replacement screen.
Score 2
Add a comment
Yes! You can find the replacement screen here: Galaxy Tab S 10.5 Screen
Replace a front glass digitizer screen display compatible with the Galaxy Tab S 10.5 model tablet. Features a 10.5 inch HD 2460 x 1600 AMOLED Display. Includes the Front Frame and Bezel. Image
Product
$157.99
Score 1
1 Comment:
what the cause of it
by
Add a comment
Add your answer
the shadowlessblackstar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 42
All Time: 483
