Android tablet released in January 2015. The Dell Venue 8 7840 has an 8.40 inch display with a resolution of 2560 pixels by 1600 pixels.
Screen Tearing and Low Battery
NOTE: Not a Dell Venue 8 7840
Hello, Recently bought a Used Dell Venue 5050 (Not Pro) it booted up fine then Last Night i started getting Screen Tearing wondering if its the battery or the O.S.
Also its running android Lolipop
And Battery was only holding 25% Charge as of Last Night
Thanks in Advance, Andrew
Add a comment
1 Answer
Chosen Solution
@born7 screen tearing should not be a battery issue. That is usually caused by the OS and/or memory. Try to charge your battery completely and then reset your software.
Score 1
3 Comments:
Then what would you recommend how do i run tests for bad memory or O.S. on Android or do i have to connect it a computer and factory reset it
Also how do you go about factory resetting this model of Dell Venue (5050) (Non Pro)
by
@born7 for a reset, this should work for your tablet. https://www.hardreset.info/devices/dell/...
by
now this "Battery was only holding 25% Charge" could definitely be a battery issue.
by
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 283
