Seventh generation laptop released in 2015. The Alienware 17 R3 is a high performance gaming laptop.
Why I cant connect to gmail?
I was having alot of problems with my laptop now . I cant access to any things but i was connected to wifi . I have tried many methods but none of them works for me. For example , i can’t connect to gmail , i cant download anything in microsoft store , and i cant even drag an image to here . LOL . ERR_SSL_BAD_RECORD_MAC_ALERT , 0x800704cf and more things is stopping me . HELPPP PLSSS
Add a comment
Most Helpful Answer
Hi CKStereAngel
What had you tried? just it happened recently?
I have a feeling OS might be corrupted.
check hard disk health if possible.
if possible, you can consider on SSD drives too.
Try doing backup of your data and do a clean install of OS.
I suppose you are using win10.
suggest you yo download the usb installer tool from microsoft, format and reinstall.
once the computer running well, suggest you also check for any bios update on your laptop.
Score 1
Add a comment
May be because of DNS overload or server bugs. Take help of google or any troubleshooting blog post.
Add a comment
It sounds like your laptop has deeper network stack or driver issues. Try these steps:
  1. Reset your network settings (Settings > Network & Internet > Advanced network settings > Network reset).
  2. Uninstall and reinstall your Wi-Fi adapter in Device Manager.
  3. Run sfc /scannow In Command Prompt as an admin, to check for corrupted system files.
  4. Use a mobile hotspot briefly to see if it’s router-related.
Also, check this guide of Certera.com Fix:- ERR_SSL_BAD_RECORD_MAC_ALERT.
Add a comment
Add your answer
CKStereAngel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 489
