The Ridgid JobMax R2851 Series B can be identified by its model number: R2851- Series B. This device is 120 Volts, 60Hz, and 4.0 Amps.
How do you remove Sleeve Spacing Assembly?
how do you remove the metal from the Sleeve Spacing Assembly ? do you need a special pulley?
Score 1
Add a comment
1 Answer
Most Helpful Answer
You could probably use a bearing puller tool? Or clamp some underneath it such that it's not gripping the axle but is providing pressure to the lip of the sleeve, then on a hard surface use a hammer to hit the axle.
Damage in any case here could compromise the quality and safety of the repair.
Score 1
Add a comment
Add your answer
Ron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 510
