The Lenovo IdeaPad 320-17IKB was released in May of 2018 and is identified by model number 80xm.
Is non removable battery good?
I would like to know if there is any way(trick) to check the battery if its still alright by not buying expensive stuff to test it with.
Add a comment
1 Answer
Most Helpful Answer
Hi,
You could always try using software - example only to give you an overview of the battery’s condition
Score 2
2 Comments:
Oh sorry considering my laptop won't turn on is based for my question.(troupleshooting), thanks.
by
Hi,
It doesn't turn on with the charger connected then?
Does the charge indicator light on the laptop come on when the charger is connected?
Does the power jack feel "loose"? Plug in the charger to the laptop (do NOT switch the charger on) and gently try to "move" the plug from side/ up and down to side to check for any movement indicating that the jack may be loose from the motherboard
Has the laptop been dropped or gotten wet at all?
Have you tried a different compatible known working charger to see if the laptop starts up?
What have you tried?
by
Add a comment
Add your answer
Telefoni will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 17
All Time: 438
