Up to 20% off select tools
Repair guides, disassembly, and troubleshooting information for the 5th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in March 2017. Identified by model number A1822. Features a 9.7" Retina display and 64-bit A9 processor.
replace battery charging port
Score 1
Add a comment
Most Helpful Answer
Ralph Cross if you are talking about the lightning port, check this guide iPad 5 Wi-Fi Logic Board Replacement step 88 and others
Score 2
Add a comment
I am not sure what you are asking, but if you are wondering what part you should replace should be easy, use an amp reader to see if the motherboard is pulling any power from the charge port if it's not then its a port replacement if it is then its a battery replacement.
1 Comment:
How do I do this?
by Share
Add a comment
Add your answer
Ralph Cross will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,166
