Portable Bluetooth speaker released in June 2015. The speaker features ClearAudio+ Technology and LDAC Technology. Model Number: SRS-X55.
My adapter is broken on my speaker
The yellow part where you charge the Sony SRS-X55 is broken. How can I replace this?
Score 1
Add a comment
Most Helpful Answer
Darla Dang that is your DC in jack. It is soldered to the I/O board. Remove that board by using this guide Then check if you can unsolder it and find a replacement based on the dimension from places like mouser. com or digikey.com etc. Not a terrible complicated repair but it does require some soldering skills.
You can get the jack connectors from here https://ru.aliexpress.com/item/202656625...
Score 1
Add a comment
The port the charger goes in the pin has come off the male component that's inside the speaker so I think I need a new connector so then I can charge as normal cheers
Add a comment
Add your answer
Darla Dang will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 713
