Up to 20% off select tools
The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
What is a printer failure?
It said “printer failure,” but I don’t know what happened that caused it. It said,
Printer Failure
There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP.
Then I took pictures:
1 Comment:
Evan, have you received any offline replies? I have this exact issue with my OfficeJet Pro 8600 Plus, using my Mac that's running OS X 10.14.4. I've done all of the suggested troubleshooting too, and now I can't even run the HP EasyStart app to check if the firmware is up-to-date b/c even tho the wifi icon is lit up on the display, EasyStart can't find the printer on my network. And I can't get beyond the "printer failure" message on the display...!
by Share
Add a comment
1 Answer
Sure looks fine internally.
Have you tried the troubleshooting steps on HP’s support site? My gut tells me there might be paper stuck in the duplexer. I’ve had that same model printer and it seemed like it was getting choked with paper constantly.
Add a comment
Add your answer
Evan Lei will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,630
