Released July 12, 2002. Identified by model number K45SSWH.
Will not start on low speeds
My 32 year old KitchenAid Mixer Model K45SS (no WH at the end) will not start until I move the speed lever to at least 5 (that gets messy!). I can then move the lever back to the lower speeds and it will work fine.
Score 1
1 Comment:
User Manual which contains information on toll free phone number for USA only (probably only for information on nearest service center and after 32 years more than likely out of date)
https://www.manualslib.com/download/1078...
That and done, your unit needs servicing. If doing the repairs yourself, open up the unit and do a visual inspection of the speed switch along with continuity and voltage testing using a multimeter. More than likely it will need replacing.
by
Add a comment
Replace the Speed Control. Here’s the part:
KitchenAid Speed Control WPW10119326
This part fits model K45SS
https://www.kitchenaidparts.com/PartDeta...
Here’s a video on how to do it.
https://www.youtube.com/watch?v=HMRqoz3y...
Add a comment
My KitchenAid Model No K45SSWH stoped will It was working, when I open the back play I found a loose pice that look as a square U with a ceramic cylinder. I imagine that I have to replace the control plate and find if I need that pice? Please let me know what part to buy
1 Comment:
please correct: should say Stoped while and the back plate instad of play
by
Add a comment
Add your answer
Mary Boudette will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 33
All Time: 6,803
