Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
Line on screen after LCD replacement
Since replacing my iPhone XR screen i’ve had this black (sometimes white) line appear when pressure is applied to the bottom right corner of the screen. If i separate the screen and phone with a layer of electrical tape the issue doesn’t occur. I assume this is some sort of electrical interference but cant seem to isolate what is causing it.
Any suggestions would be much appreciated :)
Score 6
Add a comment
Most Helpful Answer
There are two possibilities here; either the replacement screen is defective or you may have incorrectly assembled the screen.
If you still have access to the original screen, you could try installing that one to see if the problem persists. If it does, there may be some damage to the logic board (probably the connectors). If it doesn’t, the go through this guide to double-check your work as some screens, especially lower cost aftermarket screens can be thicker and cause issues with pressure points.
Also, was the replacement screen a “complete” screen with small parts or did you have to transfer everything over? Pre-populated parts can be problematic but transferring parts can lead to alignment issues. Do some more testing and verification and come back with more details.
Final question, is the picture of the phone innards your device or a photo from the web? It has an awful lot of scratches, markings and the battery looks like it has seen better days. Let us know if the phone has been previously repaired.
Score 4
Add a comment
I think you need to try reconnecting the display to the phone. True, for this you will need answers and little experience in repairing such devices. Although it seems to me that it’s best for you to turn to the master who replaced the screen for you.
Add a comment
Most likely it’s nothing than a damaged screen, thos line are normal for damaged screen, the reconection with motherboard will chang nothing, or there is possibility of cracked pin in phone connector, but this thing is the best check on another lcd.
Add a comment
Hi Elisha
i Repair iPhones for a living and that is a screen faulty and Make sure the battery is disconnected because that can damage the screen.
Add a comment
Add your answer
Elisha Mawson will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 30
All Time: 2,379
