The Dyson V6 Absolute is a cordless, bagless cleaner released in September 2014, with HEPA filtration that captures allergens. Used for all floor types and weighs 5 pounds. Identified by model number SV09.
My trigger keeps cutting out
My vacum will run for a few seconds when I first pull the trigger and then it starts cutting out
Score 3
1 Comment
Why isn't my Dyson charging?
Or you may have some intermittent component problem. Having a good power source is best for troubleshooting other potential problems so checking the battery status is a good first step.
by
Add a comment
Most Helpful Answer
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
If your Dyson v6 Absolute vacuum cleaner’s battery life is not long enough to complete a vacuuming task, see the Dyson v6 Absolute Battery Life Is Too Short problem page for possible causes and solutions.
Probably a worn-out tab on your filter not tripping the switch.
Here’s a video on how to fix it:
https://www.youtube.com/watch?v=9IUZ_Gol...
Score 1
Add a comment
Is there any blockages?
Dirty filter? This is notorious for stopping my V7.
Add a comment
Add your answer
Nola Ford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 29
All Time: 10,213
