The Samsung Galaxy A3 (2017) is a mid-range smartphone from the Galaxy A series. It was introduced by Samsung in February 2017 alongside the Samsung Galaxy A5 (2017) and A7 (2017).
Using smd rework station
Hi,
I am quite new to mobile servicing. I want to use smd rework station. While doing so, there are much opportunities for the damage of nearby components . Are there any ways to avoid damaging such nearby components?
Thanks.
Add a comment
1 Answer
Most Helpful Answer
Yep, there two ways that I use to shield surrounding components of what you are heating up.
  • Apply Kapton (Yellow non-conductive) tape to surrounding components
  • Use thick metal objects that absorb heat well like a penny / coin (if needed)
Pre-heating the board to something like 80°C will make it easier to remove the component being heated.
Avoid using a small nozzle as they are prone to blowing surrounding components away for the heat gun and don’t heat components for too long when putting them on to the board.
For a lot of my re-work I use 380-480°C depending on the heat required, this will vary between hot air stations so might want to practice removing and putting back SMD components / BGA components on dead boards first.
Score 1
Add a comment
Add your answer
S.Kumar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 236
