The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Why am I getting sru cll error
Kenmore dryer error sru cll
4 Comments
The following link says the answer is "Solved" so you might want to try it:
http://www.fixya.com/support/t26176902-d...
Kinda weird as it would appear that the docs available here and at the following link (and others I tried when searching) don't seem to mention this error code (though it's quite possible I missed something along the way)
https://removeandreplace.com/2016/01/18/...
by
It showed E63 I hope we can fix it
by
It reads E63 I don’t know how to fix it please help
by
Ours did this and gave E63 also, did you figure out what was wrong
by
Add a comment
1 Answer
Chosen Solution
Hi,
Did you mean srv cll? This could mean "service call"
Try the following to see if you can get an error code which may provide more info.
Found this on the web so hopefully it may be right ;-)
READING ERROR CODES 1. Wake the dryer up by pressing the "power" button. If dryer will not wake up, refer to Error "No Display".
2. Turn the knob to any cycle.
3. Press and hold the “power” and “start /pause” buttons simultaneously for 6 seconds to show the last error code recorded. The error code will appear in the display as an E followed by two numbers. NOTE: E00 means no failure code experienced.
4. To view the last 5 error codes recorded or to clear all error codes,
If you get any codes please reply back or search online for "Kenmore HE3 (insert error code)".
Score 2
2 Comments:
I have e35 anyone know what it means
by
@carriepelcher
What is the model number of the dryer?
by
Add a comment
Add your answer
nikkisamf will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 20
All Time: 9,594
