The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Power Button does not click after re-assembly
After putting the top on, the power button doesn’t click. It clicks fine until i clamp all the plastic clips around it in. Screwing it in or anything like that does not help either. Nothing seems to be in the way of the button either
1 Comment:
Just a thought. If switch uses mounting screws, maybe try putting some plastic washers between the heads and the computers frame to see if that makes a difference. My stance for my own personal equipment, if a solution works, it works and that is good enough for me. :-)
by
Add a comment
1 Answer
Try reseating the ribbon cable that goes to the buttons. Most likely it's slightly out of position or something.
Add a comment
Add your answer
Thomas MacGregor will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 253
