Laptop plugged in not charging
Laptop plugged in not charging and will not charge at all
Check too see if the laptop has a charging light, and if so make sure the light shows a charging indicator when plugged in. If it does not, then it could be a faulty charger or a short somewhere on the laptop motherboard. If you charger has a light on it showing its working fine and the laptop has a charge indicator showing that its not charging then it could be a short. If the charger or laptop do not have power indicators then go ahead and leave a comment for me too assist some more.
It is displaying with x sign.
No Battery
Pl suggest to resolve the issue.
Is the battery original? A lot of PC laptops have problems with the batteries after 1-2 years where they just die. If the battery has never been replaced, start there and see if that fixes the issue - it almost always does on older laptops like this.
If that doesn’t work, try removing the Microsoft ACPI-Compliant Control Method Battery device, scan for hardware changes and it will reload once it is found again - DO NOT REMOVE THE DRIVER! You will find more then one with a dual battery compatible laptop, but the Acer likely doesn’t support this.
Dual battery compatible systems:
If you are still having issues, try replacing the charger. Acer does not use a sense IC like many other companies, so you can get a good quality aftermarket universal charger, like a Targus. Either get the OEM adapter or a good universal one made by Targus.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 35
All Time: 977
2 Comments
Excellent article! I recently faced a problem where my laptop showed "plugged in, not charging" even though the charger was connected properly. Your explanation of checking the power adapter, battery health, charging port, and power settings is very informative. This issue can be frustrating for many laptop users, so having a clear troubleshooting guide like this is really helpful. Thank you for sharing such practical tips. I look forward to reading more articles on laptop battery and charging issues.
by acerauthraipur12
Great explanation! My laptop has been detecting the charger, but the battery level stays the same and never reaches a full charge. I tried changing the power outlet, but the issue still exists. The suggestions shared in this post give me a better understanding of what could be causing the problem and what to check before considering a repair. Articles like this are really helpful for users looking for practical solutions to common laptop charging issues. Thanks for sharing your knowledge.
by acerauthraipur12
