Up to 20% off select tools
The TI-89 Titanium is a graphing calculator developed by Texas Instruments (TI) and released in 2004. TI-89 calculators include a computer algebra system that allows the symbolic manipulation of algebraic expressions.
missing horizontal pixels on display screen
I have two missing horizontal lines of pixels. The first is just below the tool bar and the second is almost half way down the screen. I ran the self test for the calculator and confirmed that the lines were missing. Is this a hardware problem or software problem. How can I determine which it is. If it is a software problem will a reset fix it without removing the factory installed programs. But if it is a hardware problem would this be an easy fix.
Add a comment
Most Helpful Answer
Hi this sounds like a hardware problem. Unfortunately, unlike the TI 83 and TI 84 lineup, the TI 89 ti doesn’t have a standard ribbon cable you can fix, instead TI attached everything to one piece making it nearly impossible to fix yourself. Even the most skilled calculator enthusiasts I know haven’t been able to repair a TI 89 ti display. :(
I’m sorry I wasn’t able to help you repair it, however if you have any other questions I’ll be happy to answer them.
Score 1
Add a comment
https://www.cemetech.net/forum/viewtopic...
Add a comment
Add your answer
Lawrence Dunbar will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 38
All Time: 2,032
