Repair guides and support for motorcycles manufactured by Triumph Motor Company.
gas leaks from carb
when i turn the fuel on gas well leak out of the air box
Add a comment
Most Helpful Answer
@baylor we would at least need to know what model and year your bike is and what you have checked. Most common problem is a stuck needle valve that will then disable the float and causing the carb to flood. Check that first,
Score 1
Add a comment
03 triumph America . hears what’s going on i’m trying to get running witch I did the bike went thew katrina and my buddy got it for parts for he’s bike all he needed was the front tire .he gave me the bike so I could get it running . witch I did . we rebuilt the carbs and set them up . we tested them before we put them on the bike and they we had no problems .put them on the bike and they pee out the airbox . we’ve had them on and off at least 4or 5 times and reset them .and yes new needle values.
Add a comment
Add your answer
ruger417 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 450
