Up to 20% off select tools
The Cadillac DeVille was originally a trim level and later a separate model produced by Cadillac. The first car to bear the name was the 1949 Coupe de Ville, a prestige trim level of the Series 62 luxury coupe.
How to change radiator
how to change radiator in 2006 Cadillac deville DTS
Add a comment
1 Answer
Most Helpful Answer
Hey Reezy.
If you’re mechanically inclined and have the tools and facilities, etc., all you need is patience and the step by step instructions to take on and accomplish this replacement. While it’s not rocket science, it is a bit involved, and you do have to get it right. Be aware, the transmission oil lines require a special tool (or alternative) for disconnection of the quick connect lines at the radiator. Although this is for the 2006 CTS (not DTS) series, I did find one very informative and complete step by step video that might be most helpful for you -
https://www.1aauto.com/how-to-replace-ra...
I’d suggest watching the video first to gauge if this is something you can hope to do on your own, or if you need to consider alternatives. Otherwise, this video should be sufficient to prepare and guide you throughout the replacement (with some degree of variation expected).
Hope this helps, and Good Luck.
Score 3
Add a comment
Add your answer
Reezy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 698
