The second generation was introduced as a 2003 model at the 2002 Chicago Auto Show, based on the new Impreza platform, featuring several fine-tune improvements over the past model.
Why is the engine knocking after overheating
I ran the car out of oil almost completely and it overheated it's never overheated before it's been over a hundred thousand miles on it and now the engine knocks when we turn it on and I just put new oil in it. What do you think the NACA Muse
Add a comment
1 Answer
Chosen Solution
Matthew Hyatt  This “I ran the car out of oil almost completely and it overheated” could be indicative of some major engine damage. From main bearings, to piston/rod damage and camshaft/ lifter/valve damage. I suggest that you have a mechanic at least do an inspection since it is a bit too much to go over. There are just to many variables with this.
Score 3
1 Comment:
Thank you. For the record it was actually my girlfriend after I told her to put oil in it and ran it out of oil and overheated when I showed up it was knocking and had her to shut it off this is exactly what I told her that your answer confirmed it thank you very much
by
Add a comment
Add your answer
Matthew Hyatt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 1,611
