Introduced on August 23rd, 2007, the Nikon D300 is a 12.3 megapixel semi-professional DX format digital single lens reflex camera produced by Nikon Corporation.
The screen is not turning on
I have a Nikon d300 but the screen is not turning on I can only see what view finder but not the screen I don’t know what’s wrong with it
1 Comment
Camera is of
by
Add a comment
1 Answer
Most Helpful Answer
Hi @junjunman93 ,
Can you view the menu screens in the LCD display?
If not, try shining a torch at an angle close to the screen to see if you can detect either an image or the menus. It will be very faint so try it in a darkened room to improve the chances of seeing anything if it is there.
If you can detect an image (or even if you can’t), on the screen then there may be a problem either in the LCD display, LCD display flex cable connection to the motherboard or the motherboard.
Try taking a picture and downloading it to a computer. I realize that you cannot see the image in the LCD screen.
If the picture is OK then there may be a problem with the LCD screen, LCD flex cable connection or hopefully not the motherboard.
Here’s a link to a video that shows how to replace the LCD screen in the camera. It is also useful so that you can check that the flex cable connections are seated properly on the motherboard.
If required, replacement screens are available online. Just search for Nikon D300 LCD screen to get results for suppliers of the part.
Score 2
Add a comment
Add your answer
jose sanchez will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 46
All Time: 1,866
