The K-Gro PowerPro is a ridable lawnmower built for K-Mart by MTD and Murray. Released in 1997. Model numbers: 13AL452F120 (38", 12 HP) & 13AQ695H120 (46", 18 HP).
fuel not reaching fuel filter
The fuel does not reach fuel filter. When you apply suction, fuel comes out of hose. Does this model have a fuel pump?
1 Comment
What model is it?
by
Add a comment
1 Answer
Most Helpful Answer
Completely common for a vacuum powered fuel pump on riding mowers. Follow the gas line from the tank and look for a square ~1.5” “sandwich” with 4 bolts and 3 hoses. Hoses are gas in & out and vacuum pulses coming from the crankcase. Disconnect the hose at the carb and crank the engine - no gas means pump diaphragm has failed.
Score 1
Add a comment
Add your answer
ROBERT ROSENKRANS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 436
