This page includes repair information for the ASUS K556UA. The device is similar to other ASUS K Series laptops manufactured by Intel and contains a support guide for long-term usage.
ASUS F556U , replacement of battery.
When all screws are removed from bottom and removal is attempted, all seems to pop off except one outer corner hear Disk tray. I find no additional screws located anywhere. Don’t want to break the plastic.
Score 3
Add a comment
Chosen Solution
Model variations in ASUS F556 series?
Try below, with screen hinge oriented at the top, for the hidden screws.
On the bottom side there is one hidden screw to open the RAM compartment under a little plug and three screws inside the RAM compartment and one under left (screen hinge and DVD side) top rubber foot.
Also keep track of screws as there are different sizes!
Score 3
Add a comment
There’s always one more screw. It may be hidden under a self-adhesive foot, or a little circular self-adhesive screw cover. It might even be under a self-adhesive identification label, tamper-evident label or “void your warranty here” label.
Score 1
2 Comments:
Thanks for that but , no other screw located. Not under rubber , or label.
by
??? !!! model variations !!!
A dead battery is of no use.
I am only speculating but maybe the mystery screw is on the other side?
If this fails...well it is up to you.
Good luck.
by
Add a comment
Add your answer
Bernard malloy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 2,127
