Repair and disassembly guides for the Compaq Presario CQ40.
Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
Score 2
5 Comments
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
by
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
by
If its pure, then you should use it. My answer is YES!
by
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
by
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
by
Add a comment
Most Helpful Answer
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
Score 1
1 Comment:
thanks for answering
by
Add a comment
Please look at this question: What are Professionals Using for Screen Cleaning
Score 1
Add a comment
Add your answer
Amr Ateef will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 732
