Up to 20% off select tools
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
How to replace hinge guard
how do you remove and place the hinge guard?
1 Comment:
If you checkout the ifixit tear down of the C202 in step 8 they remove the display from the rest of the case and it looks like that plastic cover is still attached. I have seen these often as just ‘wrap-around’ pieces that can be carefully popped off of short partial shafts on either side. You should be able to flip that piece back and forth with the display detached if need be.
by Share
Add a comment
1 Answer
Add a comment
Add your answer
GanSolo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 750
