• Input jacks: iPod™ dock connector / 3.5 mm stereo jack • Speakers: 2x Ridge TM tweeter/mid-range drivers and 2 x Atlas TM woofers • Amplifier power: 2x15 watts tweeter/mid-range, 2x30 watts woofer • Frequency range: 40 Hz – 20 kHz • Input impedance: >10kOhm • Power supply: 8x D battery/replacement battery, power adapter • Dimensions (LxWxH): 500 mm x 230 mm x 240 mm
Standard vs. Rechargeable batteries
Hello,
My Harman Kardon go play 2 takes 8 D cell batteries. Each being 1.5 volts, that makes 12 volts of power. Rechargeable batteries operate at 1.2 volts giving me 9.6 volts. I've read that some electronics are sensitive to voltage changes like this and will fry while others are not. Is it safe to use rechargeable batteries in the Go play 2?
Thank you
Add a comment
Chosen Solution
Hi Tyler media,
Well, I guess you can try, I think is a good investment.
For me, I do buy many rechargeable batteries, somehow for alkaline batteries, if left out for long time, the probability of leaking is high and the leaked chemical can damage terminals and seep into the circuit board, damaging it further.
You need to get a battery charger.
Some say Nitecore D4 is great, which I had one too
And perhaps AA to D cell converter / adapter
I had several batteries, ranging from Panasonic / Sanyo Eneloop and recently using Ikea Ladda battery.
I think if your side has ikea, you can consider it.
For this appliance I will recommend you to go for Eneloop pro series from Panasonic or Ikea Ladda 2450.
Link
https://www.panasonic.com/global/consume...
https://www.ikea.com/us/en/catalog/produ...
Interesting Reead
https://petapixel.com/2018/02/16/eneloop...
Score 2
Add a comment
وواتننتن ادااا اهخخ ههههت تتتت تتت
Add a comment
Add your answer
Tyler media will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,661
