Up to 20% off select tools
The Shark Rocket HV301 is the second installment of vacuums in the 300 series. It is a two-in-one vacuum that comes with several attachments, making it capable of cleaning on different surfaces. Its sleek and lightweight design make it easy to maneuver around any household.
will nt pick up
dirt goes into the stick and gets cloged up have to take the stick and clean it and dose pick up. when i first got it i loved it. but right now it is worthless.just bought a navagater and is very hard to push.no more sharks for me.can you please tell me where i can get the rocket fixed. thank you. i live in rogersville tn.
Score 1
Add a comment
1 Answer
You may have a partial clog somewhere along the way that is keeping you from getting full suction. Try this - without the power head or rod attached turn on the vacuum, now place the palm of your hand where the rod would normally attached. Does it pull your hand towards it? If so, repeat the process by attaching the rod only. If there wasn’t good suction before attaching the rod, you likely have a clogged filter or collection chamber; try cleaning the filters with some warm water and fully empty the collection chamber. If the suction was good there, but bad after connecting the rod, then you have a clog somewhere in the rod. You might be able to fish it out or break it loose with a straightened coat hanger. If suction was good at both of those places then take a look at the hose that is at the bending point of the power head, here is where that hose will crack (this was the case for mine). A crack in the hose will lead to poor suction. Best of luck fixing the issue.
Add a comment
Add your answer
barbara bond will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 369
