Up to 20% off select tools
The Surface Laptop 2 by Microsoft was released October 2018.
Screen is damaged internally
Screen doesn’t show physical damage only internal.. How can I fix this?
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
As you can see, in the upper right corner of the screen there is a crack (circled in red) in the liquid crystal layer of the screen, which is most likely causing the horizontal lines going through the LCD. I would send the the laptop to a repair shop for them to fix it for you because the Surface Laptop is very, very difficult (or maybe even impossible!) to open up with out inflicting lots of damage to both the internal components and outer casing.
Score 1
1 Comment:
This kind the issue can not been fixed but replace the whole LCD so far
by Share
Add a comment
Add your answer
Ailyn Gonzalez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,717
