The DKnight MagicBox II is a small portable Bluetooth speaker with Enhanced Bass and build in Microphone for hand free phone calls.
What is the name of this component?
Please check the attached image, I have marked the component. I just need to know what is the name/model of this IC/Component. This burnt out, I can’t recognize its name/model. I want to replace by myself.
Thanks!
1 Comment:
Sure looks like a DIode. You do want to go ahead and try to post a couple of images that are less blurry and are closer to the component.
by
Add a comment
The photo is a bit blurry. Is there a map of this system board on its manufacturer’s website?
Add a comment
The component you circled can be either a diode or transistor. It has 3 leads and is the SOT-23 case style. Look at the top and get the code that should be written there. Search for that code like this on google: “SMD CODE xx” where xx is the code you read. That should help to determine the part.
Dan
Add a comment
Add your answer
Jobaer Shuman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 236
