Up to 20% off select tools
The Canon EOS Rebel T3 is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. Also known as the EOS 1100D and the EOS Kiss X50, it features a 12.2MP sensor and a DIGIC 4 image processor.
How to fix error 30
An error 30 occured in my Canon D1100 EOS.. what shouild i do to fix this.. am even getting worse. help the one who knows the solution
Add a comment
Most Helpful Answer
@davie77 Err 30 seems to be vry common problem with this model
Description: A malfunction with the shutter has been detected.
Resolution: Turn the power off, then remove and re-install the battery. Then turn the power on again.
Other than that it sounds like a either a stuck or failed shutter. You could call Canon support for your place of residence and see if this is still covered under a “recall” that was happening a while back.
Score 3
Add a comment
Error30 on Canon 1100SD> in fact the SD card reader has its oxidized contacts> I used contact spray for electronics with a little brush on the contacts of the SD card> I put the card back in the reader / removed and put it back several times / I leave to act overnight AND now no more errors30 ;-) —from a french guy
Add a comment
Add your answer
Davie ogallo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 2,694
