The Shark IONFlex 2X (model IF251) is a lightweight, cordless vacuum. It includes the handheld vacuum, motorized floor nozzle, wand, and two rechargeable lithium ion batteries.
Brush roll removal possibility
Is it possible to remove and replace the hard brush roll?
Score 1
Add a comment
1 Answer
It looks like you can remove it:
  1. Remove both brush roll bands (use existing guides)
  2. Remove the two screws near the left end of the hard brush, the one with a large white gear.
  3. Slide the long thin flat brush on the bottom out through the side
  4. Lift the two metal wires you just exposed supporting the hard brush on the bottom
  5. Push the hard brush from the right end and it should slide right out.
I haven’t found replacement parts for it yet, and the hard-to-reach parts where hair might gather that are still hard to reach unfortunately.
Add a comment
Add your answer
Paul skinner will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 759
