The Fitbit Alta smart wearable by Fitbit was released in 2016. It features a tap-activated display screen that is slightly smaller and thinner than comparable models.
Fit bit exclamation and no charge
Fitbit doesn't show anything but an exclamation mark. When off the charge port it is dark.
Score 1
2 Comments
it still shows the exclamation mark with the battery sign. I am trying to change profiles. please help!
thanks.
by
Add a comment
Chosen Solution
The exclamation mark usually means one of two things. You either waited too long to recharge your Charge and the battery is fully depleted. Or else an error occurred during a firmware update, in which case restarting your Charge and leaving it plugged in afterwards will cause the update to resume and complete.
How to Reset : Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the Fitbit logo appears on the tracker's display. This indicates that it has restarted.
Score 6
4 Comments:
Thank you so much !! It is charging!!
by
no button on the charging cable.!
by
Is there any way to have the Fitbit work again if I waited too long to recharge and battery is depleted?
by
No button on versa 2 charging cable.
Mine has battery sign with exclamation mark2023, always charged ok. Now can’t sync as won’t find watch
by
Add a comment
check this video it may help you to using your galaxy fit '''https://www.youtube.com/watch?v=g223JepU...
don’t forgot to say thanks
Add a comment
My fit bit charge to is your not exclamation sign when plugged in to chargeMy fit bit charge to is your not exclamation sign when plugged in to charge
Add a comment
Add your answer
Stefanie Franco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 159
All Time: 44,032
