Repair guides, disassembly, and troubleshooting information for the third-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2012. Identified by model number A1426. Repairs require the use of heat and careful prying.
It will not set up
I recently got the screen changed on my iPad 3. It is reset and when I go to set up, it gets to the “it may take a few minutes to set up” message and then after a minute it simply starts back over like it is a new iPad needing to be set up. How do I fix this?
Add a comment
Most Helpful Answer
Before opening up the iPad make sure the iPad is up to date via iTunes and 3utools. You can also use 3utools to activate the iPad.
Score 1
Add a comment
Try taking all the ribbon cables out and putting them back in.
Add a comment
Add your answer
Cody Slovensky will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 16
All Time: 304
