The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
turns over but will not fire
my car has gas in it does not stall or hesitate was running just fine until a couple days ago it died while idling started right back up but when i parked it when back out a while later it wont start turns over but wont fire
2 Comments:
2002 grand prix.replaced fuel pump.it kicks in but wont start and backfires?any help?
by
If there is old gasoline in the tank it may have turned into water. Try adding some dry gas to the tank.
by
Add a comment
Check for spark at plug wire, if no spark check ignition fuse if ok check coil pack if ok you may have a broken timing belt
Add a comment
I had to replace the fuel pump in mine.
Add a comment
Add your answer
mkazee81 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 23
Past 30 Days: 39
All Time: 2,828
