The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
Every gear is drive
I have a 96 automatic 4 speed 4x4 ranger… I just replaced the gaskets and valve body and solenoids in the transmission along with filter. I have everything back together but the truck thinks every gear is drive. Why could this be?
1 Comment:
It ended up being the gear selector valve, since it was a new valve body I never pulled out the gear selector valve and made sure it was aligned with the valve.
by
Add a comment
1 Answer
It seems like an issue with Transmission. First verify the gear shifter is connected properly, and if possible attach images of the new work you did with the Transmission.
2 Comments:
Problem is I never touched the shifter on the transmission. All I did was bought a new valve body for the transmission. With new solenoids filter and gaskets. New valve body came pre-assembled with gasket already on the inside. All I did was place the new gasket on the outside between the valve body and transmission. Bolt the valve body on the transmission, bolt up the servo cover , connect plugs for the solenoids power, bolt on the filter and then bolt up the pan. Put in fluid and then connect the battery ... Then I turned on the car and then have no gears besides drive. Park is drive reverse is drive...you get the point.
by
Hey I am having the same problem with my 2001 Chevrolet s10 with every gear stuck in drive and I fixed the transmission myself as well but ran for a while so would you be able to go into detail about how you resolved the issue?
by
Add a comment
Add your answer
Charles Stewart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 549
