4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
iPhone SE restart when press home button
Hello,
according to my previous question (iPhone SE cannot be turned on after dropping to the floor), my iPhone can be turned on. I did restore and update already. It can show the first screen as show in the following picture.
However, when I pressed the home button to start, it was restarted. After that, the apple logo showed. It presented the first screen again. It has no problem without press the home button.
I tried already to use a new charging port, which also consists the new connector for home button. Nevertheless, the problem can not be solved.
I think it may be the problem from home button or logic board.
Does anyone used to deal with the problem like this or have any idea to solve it?
Thank you very much
Add a comment
1 Answer
Most Helpful Answer
It’s a bad home button if it does not allow it to boot up the phone while it’s pressed down.
Score 1
2 Comments:
Thank you very much
I have ordered a new home button.
by
I have changed the home button but the problem cannot be solved.
by
Add a comment
Add your answer
Nalin Loypetch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 598
