HP Officejet Pro 8620 is a multifunction printer for copy, scan and duplex. This device can be identified by its model number: SNPRC-1401-02
Solid Black line on copy
  1. How do I eliminate a solid black line down the right side of a copy that only occurs when I use the paper feeder to make copies on my HP Officejet Pro 8615 printer/scanner/copier??
Add a comment
1 Answer
Chosen Solution
Hi @flgallows ,
Try cleaning the scanner glass under the ADF.
Any speck of dirt or grime on the scanner glass will create a solid line as it is between the scanner sensor and the document being copied.
Here’s an image taken from p.34 of the user manual showing how to access the scanner glass and where and how to clean under the ADF.
(click on image to enlarge for better viewing)
Score 2
2 Comments:
how do I clean the ADF glass strip underneath? It has a cloudy film on it.
by
@Ken Keehn
Use a clean lint free cloth (microfibre cloth works well) slightly dampened (not dripping wet just damp) with clean water and rub gently.
If it won't come off with water then use Ispropyl alcohol 99% (available at electronics parts stores) and dampen the cloth with that.
Disconnect the power from the printer when doing this as you don't water or any liquid from entering the machine with the power connected. Even with the power disconnected it can cause problems so use only a slightly damp cloth.
by
Add a comment
Add your answer
FrankGalloway will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 3,298
