Sony’s Cyber-shot DSC-W830 is a 20.1 megapixel camera designed to capture still images and video recording up to 720 pixels.
How to fix error C:13:01? re-insert memory card?
I have sony DSC-W380, then suddenly after using cannot open file. the image was C:13:01, re insert memory card. how to fix it?
Score 1
1 Comment:
I had the SAME PROBLEM! On the SAME CAMERA! I need to know this answer ASAP. I re inserted the memory card and that didn't work. I tried another card, that didn't work.
by
Add a comment
1 Answer
I had this error about five years ago in a  Cybershot camera.  The error seemed to be caused by a bad contact  between the camera and the memory stick.
I gave the camera's slot a blast  of compressed air, cleaned the contacts of Camera & Memory Card and inserted &removed the  memory card several times in quick succession.
And this solved the issue.
3 Comments:
I already did but its the same, no changes. =(
by
If there is no important data on it, try to format it using PC/laptop
by
cannot also detect on PC/Laptop. yes it has important data.
by
Add a comment
Add your answer
Joefine will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 4,423
