Up to 20% off select tools
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Screen Jumps While Charging With Case
So my problem still hasn’t found a light tho.
But now, I know my screen only jump if I don’t hold the phone naked when charging.
If I put case or if I don’t hold the phone, the screen will jump a little when charging.
Add a comment
1 Answer
Chosen Solution
This is a grounding fault with an aftermarket replacement screen.
To get that fixed you would need to get a higher quality screen put on the phone such as original, OEM or refurbished screen.
Not really worth fixing imo if the touch screen works fine without charger plugged in.
Score 1
2 Comments:
Ahhh... I see, gonna try another LCD if there’s available tho..
Hope this will fix it! Thank you
by Share
Hey there. I know it’s late but did you change the screen? And if u did, did it change anything? Thanks.
by Share
Add a comment
Add your answer
Simon Setyadarma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 963
