The Sony Handycam DCR-HC51 (product code DCR-HC51E, product name DCR-HC51) is a camcorder with a touch LCD (liquid-crystal display) screen and 40-times optical zoom.
How to fix error c 32.11
i tried hitting the bottom diconeecting power and shaking it
Add a comment
Most Helpful Answer
This error code indicates that the tape itself is not moving and the unit has shutdown to prevent any damage to the tape. There are a number of possible causes for this since it is a generic error message. There can be a loading problem, or the takeup reel is not moving or there is no movement of the tape at all. In any case, this problem will require further investigation by a service provider. Without seeing the actual camera and investigating internally, there is little that can be done in this forum.
Score 1
2 Comments:
most likely is mechanical problem you may fix it if you are mechanically inclined the mechanism may need a good cleaning and a little oil and you are on your way to your recording I love my hvr z7
Nick y
by
Be very careful with oil in a tape unit. This is the most common cause of complete failure. Any oil where is shouldn't be often results in the tape adhering to the heads and other parts. I would NOT suggest using oil at all.
by
Add a comment
Kassetefach geht nicht mehr , Fehler C32 - 11
Add a comment
Add your answer
alex will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 47
All Time: 1,816
