Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
Not turning on and volume buttons
How do I fix my power button and volume buttons. Neither one of them will work. It won’t turn on unless it’s plugged in. Can b played on after it’s unplugged but if it turns off u have to plug it back in to turn it back on
Add a comment
1 Answer
Chosen Solution
Hi @mad1066 ,
If the tablet works OK when it is plugged in i.e. the Power and Volume buttons work OK, it sounds as though there may be that the battery is failing and not holding its’ charge. Even rechargeable batteries have a life span.
Try replacing the battery and see if this resolves the problem.
Here’s a link to the ifixit Kindle Fire HD Battery Replacement guide which may be of some help.
Replacement batteries are available online. Just search for Kindle Fire HD 2012 1st Gen battery to get results for suppliers of the part. Ensure that you order the correct part. Check the model number of your tablet (found on the back of the tablet or in the Settings area) to verify that the battery is for your model Kindle.
Score 2
Add a comment
Add your answer
Donna will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 996
