Up to 20% off select tools
The Kodak EasyShare C913 is a 9.2 MP digital camera.
What does .AF mean?
When you push down the flash, it goes off but than it goes off AGAIN and the picture turns out as just a white blob. Why does the flash go off the second time?
Score -1
2 Comments
Laura Gross, just as a follow up, I was wondering if you got your camera working again.
by Share
Midway Island.
by Share
Add a comment
1 Answer
Chosen Solution
Not sure about the .AF. It would depend where it shows up on your camera. I do believe that it shows that your Auto Flash is on. The double flash is done by your setup. For Red-eye The flash fires twice—once, then again when the picture is taken. So you should check your manual, available here,and see how to turn it off. I hope this helps, good luck.
Score 1
Add a comment
Add your answer
Laura Gross will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 957
