A followup to the LG V10 smartphone, similar to the LG G5, released on September 29, 2016. The LG V20 can be distinguished by the model numbers F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996, and VS995. It is available in titan, pink, or silver with 32/64 GB of storage.
How can I get my display to work again?
My screen came out so I took the phone apart and re-glued the screen with some 1mm 3M tape. Now I reassembled it and it vibrates on boot and I can see the backlight go on because a corner of the screen is broken off… Also WhatsApp Web works. So the phone is definitely working, but the display isnt showing anything (Backlight does work tho)… I re-checked the main screen connector at the bottom and it is properly plugged… what can I do?
P.S.: I followed this tutorial for the process: https://www.youtube.com/watch?v=oDEZjsqN...
Score 2
Add a comment
1 Answer
The LCD is for sure broken. In order to get a display back, you will need to replace the screen.
part can be found here: https://www.fixez.com/store/lg/lg-v-seri...
Having a screen with frame saves you the hassle of having to re adhere the screen to its frame, so personally I would go with that part.
Repair tutorial here: LG V20 Display Replacement
Note: If you buy the screen with frame, you start putting your phone back together after step 15 in that repair guide, if you buy screen only, you will follow the entire tutorial.
Add a comment
Add your answer
Raphael Nollau (R4PHikari) will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 54
All Time: 400
