Up to 20% off select tools
• Input jacks: iPod™ dock connector / 3.5 mm stereo jack • Speakers: 2x Ridge TM tweeter/mid-range drivers and 2 x Atlas TM woofers • Amplifier power: 2x15 watts tweeter/mid-range, 2x30 watts woofer • Frequency range: 40 Hz – 20 kHz • Input impedance: >10kOhm • Power supply: 8x D battery/replacement battery, power adapter • Dimensions (LxWxH): 500 mm x 230 mm x 240 mm
How to replace broken speaker
How can I replace the speakers?
Score 1
Add a comment
1 Answer
If you can get into the device it should be as simple as de-soldering the two wires connecting the speakers to the main board. Then you would need to get a replacement speaker of the same size and power as the one already in the device which may or may not be a propriety size speaker.
The hard part would most likely be figuring out how to open the speaker which I cannot help with since I don’t own one and have never worked on one. This procedure is just how I have changed speakers in multiple different PC speakers or iHome type devices.
Add a comment
Add your answer
abelplus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 46
All Time: 3,502
