A Sony turntable that can convert the music on records into MP3 files via a USB connection.
Fuzzy audio after replacement stylus
I came home and found that the turntable had been switched on and the stylus had been dragging on the rubber mat. I have no idea how long this had been running. Assuming the stylus would be damaged I have put two new stylus' and it is still sounding fuzzy. Could it have affected anything else?
Score 1
Add a comment
1 Answer
Chosen Solution
It sounds like the excessive drag on the stylus has somehow distorted the transducer mechanism. You should be able to get a new pickup cartridge quite easily and fit it to the existing pickup head.
Score 1
Add a comment
Add your answer
David Atack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 516
