Sony CFD-S05 CD Radio Cassette Player was released in 2010, and has the CD-R/RW playback function.
cassette will not play when powered up
I have power for the radio and cd but when I switch to tape it will not run , just the display indicates “TAPE”. The belt drive is not damaged and it seems that the motor will not run . Is there a test I can do on the motor ?
Add a comment
1 Answer
Chosen Solution
If you can, touch the probes of a multimeter on a voltage range on the connections to the motor, and see if you can see some volts when you press Play.
Are you sure the belts are ok and the motor isn’t turning? If it’s some years old the belts may well have perished and gone slack. It would be somewhat unusual for the motor to have failed.
Score 1
Add a comment
Add your answer
David and Lori Hurley will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 26
All Time: 388
