The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
sim recognized but no signal!
Hello Guys !
I have the Xiaomi Mi A2 Lite,
great budget device and it was working perfectly, until one day i woke up and found that both sim cards have “no service” but i can see the operator name detected in sim settings
i’ve tried everything like factory reset and *#*#4636#*#* but no solution
could please see about that guys
Score 5
2 Comments
I looked around and saw something about an October update causing issues with celular connectivity
by
@connor2003 yes i think that too
because i updated the phone to android 9.0 few days before the "no service incidence"
i'll try to flash it and see
by
Add a comment
Most Helpful Answer
If I were you, on the issue of SIM connectivity, the first thing I would do is call my carrier, ask them if anything happened on their end. That what you should probably do as well.
Score 2
1 Comment:
no I've tried them on other devices and they work perfectly !
by
Add a comment
after 2 months of struggling
i took it to the repair store
and he only flashes it with the proper firmware
and its working since
Score 1
2 Comments:
Thanks for the quick answer. I tried to flash it but it didn't help. I'll try to find a repair store that fixes software
by
can you please check and tell me which version of firmware you have flashed from repair shop?
by
Add a comment
Same issue here, with my A1. Since the Android 9.0 Update no signal.
Downgrade to 8 did not help.
Did you make any progress?
1 Comment:
i flashed it but still no progress
i think that the 9.0 update provoked the problem on sim card reader board
its a hardware problem with this device
cuz a lot of people are having it
check this out
https://en.miui.com/forum.php?mod=viewth...
by
Add a comment
Got the same issue, did you manage to fix it?
Add a comment
Same issue, no service issues on mi phone after last … such a problem phone.
Add a comment
Yes, I'm having the same problem. I tried every alternative. I even called customer care service to check if it was a problem with my son but they said it's active. I tried resetting everything but it didn't work. I even tried restarting the phone but it still doesn't work. Please let us know if you have any solution to this problem
Add a comment
I have the same problem
1 Comment:
I have the same problem too. What things to do guys
by
Add a comment
Hope this will help you
https://okadtech.com/xiaomi-redmi-note-4...
Just go and solve your problem and thanks me later
Add a comment
Add your answer
MATHIL will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 38
All Time: 15,710
